Home » Topics » Main Forum » PIPER MODELS » PA-32 » Engine hesitation/ quit
    Joseph Signorino on August 29, 2021 at 5:29 pm #20919
    Hello Steve and Brandon,
    I wanted to pick back up on this issue as it relates to the idle issue Brandon was experiencing.
    Back in Nov of 2020 I reported everything was working great after the mech pump, fuel injector, etc was rebuilt. There was a problem with the mechanical pump. Around May or June I started noticing a problem similar to what Brandon described, with electric pump ON idle is perfect, With the electric pump OFF the engine does not what to idle below about 800 RPM. I/we have done some testing of fuel pressures and flow (on the JPI) with the electric pump on and off. I could type a lot of info but a few items stand out.
    1- The fuel pressure with the electric pump ON and the engine OFF is 38PSI.
    At idle aprox 650RPM-
    2- With the engine running and the electric pump OFF the mech pump pressure is 37 PSI.
    3- Electric pump on (both pumps) about 43 PSI
    This is where it seems odd:
    4- Fuel flow on the JPI with electric pump on reads 1.8gph (engine idles great)
    5- FF with electric pump off reads 3.0gph? (idle problem)
    6- Idle mixture is set by the book (electric pump on) for a 50RPM peak when leaning mixture, I do not get this peak with the electric pump off but the manual states the electric pump MUST BE ON to set idle speed and mixture.
    So I am a bit curious if others experience idle issues wit the electric pump off? It sounds like Brandon fixed his issue? Also can anyone provide me with the fuel flow data with electric pump on and off if you have an engine monitor setup?
    Part of what puzzles me about this is it worked great for 6 months (colder weather), also when reading in detail the POH states the electric pump should always be ON for all ground operations, etc except when testing the mech pump? My checklist was written different and I have for 10 years turned the electric pump off after starting the engine and turned it back on prior to TO, never had an idle problem.
    Open to any thoughts.
    Joe
    STEVE on November 27, 2020 at 9:07 am #20352
    Think of it as a very welcome early Christmas present.
    Joseph Signorino on November 23, 2020 at 12:48 pm #20351
    Brandon and Steve,
    Indeed great news. I apologize for the delay in getting back with my results. It turned out my issue was directly related to the mechanical fuel pump and the fuel we found draining from the pump vent line. I now have pretty much a new/ rebuilt fuel system. After the rebuilt and upgraded fuel pump was installed the leaning procedure worked as described in the manual. The plane also performs better on departure than it has in some time.
    Joe
    STEVE on November 23, 2020 at 10:57 am #20349
    Brandon;
    That’s great news.
    Thanks for taking the time to give us feedback on what you found.
    Brandon Dorsett on November 23, 2020 at 9:59 am #20347
    Update: Turned out to be a pinched/incorrectly installed o-ring on the fuel selector valve. Caused the motor to suck a bunch of air. We had suspected the valve and went through a headache to find a replacement. Once we opened up the strainer bowl it was clearly deformed. Replaced it and it runs as smooth as can be.
    Thanks for all your time and attention.
    STEVE on October 28, 2020 at 9:29 am #20290
    The “fuel flow” gauge is actually a fuel pressure gauge calibrated in gallons.
    The electric pump pressure is controlled by a relief valve in the body of the pump, as I remember it.
    Joseph Signorino on October 26, 2020 at 5:19 pm #20287
    As I wait for the bump rebuild to be complete I was thinking about the electric pump and how it regulates the pressure. On some race engines I have had with electric pumps installed the pump stopped when the pressure built up with the engine off. The pump on the Lance runs continuously once energized. The Lance has fuel flow gauge but no fuel pressure so is it possible the electric pump is producing too much pressure? Any idea how they regulate the pressure?
    Brandon Dorsett on October 25, 2020 at 7:15 am #20284
    Good luck. Still awaiting results as well on my pump. It’s currently in Tulsa. Attached is a diagram of my system I was referencing earlier. FB5D20C9-513A-49A4-AE6A-D0D047E9F64B.jpeg
    Joseph Signorino on October 24, 2020 at 2:07 pm #20280
    Will do. If I had know how long it would take I could have just purchased a new one…
    STEVE on October 24, 2020 at 2:00 pm #20278
    I think you’re on the right track with the engine driven pump rebuild.
    Please let me know how it turns out.
Viewing 10 posts - 1 through 10 (of 18 total)
