Home » Topics » Main Forum » PIPER MODELS » PA-32 » DDMP Failure/Error code. 1998 Piper Saratoga II TC
    Jorge Velloso Filho on February 29, 2024 at 3:59 am #22409
    Unfortunately no fix for this yet… some times it boots but its rare i would say 1/100
    Its the same error here, it get stuck on the nvram test and give me that CO RE error sometimes the error number change from 2 to 4 but thats it….
    Let me know if you find any solution.
    Thanks!
    Jorge
    Jose Massis on February 28, 2024 at 8:37 pm #22408
    Hi Jorge, did you figure that out? I have a Seneca V ‘97, just got the NVRAM Test Fail and there is no info about that error, just says CO 1
    RE 0
    Let me know if you found out a solution.
    Jorge Velloso Filho on December 24, 2022 at 5:52 am #21745
    Guys
    Im having the Ddmp failing to boot as well my error is NVRAM Fail
    Any ideas how to fix it, please? Thanks!
    Merry Christmas!
    Alan Bradshaw on July 31, 2020 at 8:03 pm #20075
    Same issue experienced today in a 1998 Piper Saratoga HP 2. Did you work out a fix for this (there were no flashing red lights on the gauges during power-up) or was it a death throw requiring a replacement unit?
    John Williams on February 28, 2017 at 5:47 pm #18352
    Digital Display Monitoring Panel (DDMP) Failure / Error code.
    Today, an interesting thing happened as I was about to leave on a trip.
    I turned on master switch, The DDMP went through its normal startup and function test. Instead of everything passing the test, the CAT failed ( whatever CAT is)…
    Then the following message appeared on the front of the screen:
    DDMP OP SYS FAIL SHUTDOWN CODE 1.
    Has anyone ever seen this before or had any experience with it?
    This is the little display that displays digitally all of the information that is also displayed on the row of steam gauges below it. I believe all Saratogas from 1995 – 2003 had these. Also the 1997-2003 Seneca V also had these.
    John
