Home » Topics » Main Forum » PIPER MODELS » PA-28 » PA-28-181 IO-360 CS Prop Conversion
    STEVE on December 31, 2021 at 10:00 am #21151
    Hi Brendan;
    Unfortunately, I as the tech answer guy, have no way of knowing if anyone has obtained a field approval for this engine upgrade.
    And even if I could pass on the paperwork of a field approved change, there’s a possibility that your local FAA Flight Standards District Office (FSDO) would not sign off a field approval like this unless it had thorough documentation from a Designated Engineering Representative (DER)
    DERs are private engineers that you would pay for a engineering study that would be acceptable to the FSDO.
    One pretty simple horsepower upgrade you could bolt on in a few hours is a PowerFlow exhaust system. Powerflow sells exhaust systems that are much less restrictive than the Piper systems; opening up the exhaust system restrictions increases fuel/air charge entering the cylinders. The result is more power.
    I installed a PowerFlow system on a C-172 12 years ago and after a before and after test flight wrote that installing a Powerflow system is the quickest and least expensive way to boost engine power.
    You can learn more here: https://www.powerflowsystems.com/products/piper.
    I can’t contact them right now, but it appears as if it doesn’t have an approved system for your Archer II. But I would check as soon as they re open after the new year.
    Brendan O’Rourke on December 30, 2021 at 10:47 am #21150
    I’m searching for information on converting my Archer II from a fixed pitch carbureted O-360 to an IO-360 with controllable propeller. My internet searching has not yielded any STCs for a conversion like this. Does anyone have knowledge of an aircraft and/or field approvals like this for a PA-28-181? No, I’m not interested in selling my nicely equipped Archer to buy a Dakota; not that I’d mine having a Dakota if there was an affordable one on the planet equipped like my Archer. I fly out of many turf airports so I prefer the fixed gear vs. the retractable Arrows. I’m under no allusions that this conversion would make my Archer fly faster in cruise, but I do think there would be benefits in climb performance and cruise efficiency. Thx
