Congrats on your new(ish) airplane.
Unless it’s been modified, the oil pressure gauge is what’s called a direct reading gauge. That means a tiny copper tube is connected to a fitting (with a restrictor so if there’s a leak all the oil won’t be pumped out immediately) on the engine. This tube is connected to the oil pressure gauge.
Sometimes, especially when out side air temperatures get colder, the OP indication is slow to come up due to “thick” oil or because the capillary tube is gummed up.
This can be over come by carefully disconnecting the tube on the back of the gauge and, using air pressure blowing into the tube to push the thick oil or crud in the tube out at the engine end.
If you’re really enterprising, you can disconnect the capillary tube at the engine end to prevent the “crud” from being blown back into the engine.
Reconnect both ends of the tube; the line should self bleed to remove air.
If you have an electronic engine monitor, the cause is most often corrosion on one of the wire terminals on the wiring, a broken wire or a bad sender unit.
Let me know what you discover.
Cherokee 140 Oil Pressure Gauge Not Working
Hello Everyone:
Just recently bought a 1973 Cherokee 140 with 160HP upgraded cylinders. I am a Rusty pilot and getting back into seat after 23 years.
Had aircraft ferried from Falmouth, MA to New Haven, CT about 1 month ago. The owner, also a Jet Blue Pilot and Instructor and myself flew A/C. I thought the Oil Pressure was fine (showing). Subsequently flew Cherokee with another instructor at New Haven about 3 times since ferry. Yesterday, after taxi and run-up, it does not show oil pressure. I have my A&P license but that, like pilot license , has not been used. Need to get into things on this issue.
I will first check all connections and then borrow a gauge to make sure it is registering pressure. Then will check gauge. Any suggestions are helpfulThank You,
Bob Haight
