Home » Topics » Main Forum » PIPER MODELS » PA-28 » Ventilation Blower Motor
    Kent Shaw on September 30, 2020 at 4:43 am #20210
    You can check for cracks in the hoses by removing one end and shining a flashlight on the outside while looking inside the hose. I replaced mine with SCEET hoses instead of SCAT. I doubt that increasing hose size will do anything since air input opening will be the same. Also check wiring and compare with the service manual. My IA found some discrepancies that must have happened at the factory.
    Brian Lipscomb on September 23, 2020 at 7:47 pm #20200
    I just wrote another post seeing if anyone had data on motor amps, did you happen to check? I’m wondering the same thing, and am prepping steps to troubleshoot.
    John Barco on September 4, 2018 at 11:28 pm #18752
    Has anyone improved the inadequate blower ventilation on the PA-28 series? I have removed, disassembled and inspected the 12 V motor and system. Needs larger ducting or more CFM. Any thoughts?
