- Thank you received: 0
Question PA-28-181 Engine Thrust Angle
- Brendan O'Rourke
- Topic Author
- Offline
- Junior Boarder
Less
03 Aug 2023 18:04 #4052
by Brendan O'Rourke
Replied by Brendan O'Rourke on topic PA-28-181 Engine Thrust Angle
With the plane leveled and measuring as carefully a practical it appears the thrust line is about 4 deg down and about 3 deg right...I say 'about' because I was measuring to the prop tips which of course are pitched. At any rate nothing jumps out as being an issue.
- Kent Dellenbusch
- Offline
- Administrator
Less
- Thank you received: 7
13 Jul 2023 16:43 #4008
by Kent Dellenbusch
Replied by Kent Dellenbusch on topic PA-28-181 Engine Thrust Angle
When all is said and done please let us know if this corrected your issue.
- Brendan O'Rourke
- Topic Author
- Offline
- Junior Boarder
Less
13 Jul 2023 16:32 #4007
by Brendan O'Rourke
4 degrees down and 3 degrees right is what I need. Thx and have a great AirVenture.
- Kent Dellenbusch
- Offline
- Administrator
Less
13 Jul 2023 05:59 - 13 Jul 2023 05:59 #4006
by Kent Dellenbusch
Hey Brendan,
A response from Piper. Kent,The tech that sent the drawing to me said the engine mount is offset 3 degrees to the right. Will that be sufficient ?.
Last edit: 13 Jul 2023 05:59 by Kent Dellenbusch.
- Kent Dellenbusch
- Offline
- Administrator
Less
12 Jul 2023 18:27 #4005
by Kent Dellenbusch
Thank you for this in-depth analysis. I'm sure we'll get the birds-eye schematic and you can proceed with your investigation. I, and many others, will be interested to see what you find out.
K
K
- Brendan O'Rourke
- Topic Author
- Offline
- Junior Boarder
Less
12 Jul 2023 18:02 #4004
by Brendan O'Rourke
Long story. My airplane flies slightly left wing low with the ball centered* and will turn left without constant right yoke pressure. I've checked and adjusted every control surface, cable tension, nose wheel alignment, rudder, etc. according to service manual, no joy. I even leveled the airplane and measured half a dozen points on the wings and stabilator with a laser transit to see if anything was out of alignment; no smoking gun, all measurements were quite symmetrical. *The ball is centered when the plane is leveled on the ground. The engine was inspected for prop strike and the prop replace 600 hours before I bought it; if there was any airframe damage it wasn't logged and there is no visible signs. Wondering if the engine mount was tweaked and there's more/less side thrust than normal, however, prop, spinner, and cowl all visually look to align properly.
Time to create page: 0.082 seconds
