Question ISO PA-24 Nose Gear Strut Tube
12 Jun 2024 09:14 #4325 by STEVE ELLS
Replied by STEVE ELLS on topic ISO PA-24 Nose Gear Strut Tube
Hi Will,
Yes, very helpful.
Thanks for responding so quickly.
  • Will Starnes
  • Subscriber
  • Subscriber
12 Jun 2024 09:09 #4324 by Will Starnes
Replied by Will Starnes on topic ISO PA-24 Nose Gear Strut Tube
sent you both some photos via gmail. hope it helps.
12 Jun 2024 08:11 #4323 by STEVE ELLS
Hi Will;
Glad you found the part you needed.
It's quite possible that that crack was caused by an over turn of the nose LG by the ground crew when towing your airplane. Usually the damage from an over turn is to shear off the "stop" you can see where the crack starts at the outside of the strut housing.
I would like to feature the picture you posted in one of my Piper Q&A columns but the photo is much too small.
The following are the guidelines from my editor:
"Images should be in JPEG, PNG, or TIFF format. Minimum size for images to be usable in print is 1,800 x 1,200 pixels, 2.1 megapixels, or at least 500kb in file size if compressed JPEG. Image files smaller than the minimums listed here may not be usable. Higher-resolution submissions are always preferred."
If you have a copy of the photo that fits these guidelines, you can send it directly to the editor at Scott [AT] aviationgroupltd [DOT] com, and me at Steve [AT] EllsAviation [DOT] com, or you can use any other file sharing site Dropbox, WeTransfer, Google Drive, etc. Simply submit the
file-sharing link to us via email at scott [AT] aviationgroupltd [DOT] com.
I know this may be a bit of a hassle, but your efforts will aid us in passing on information to other Comanche owners and readers of the Piper Flyer magazine.
  • Kent Dellenbusch
  • Kent Dellenbusch's Avatar
  • Administrator
  • Administrator
01 Jun 2024 11:33 - 01 Jun 2024 11:34 #4322 by Kent Dellenbusch
Replied by Kent Dellenbusch on topic ISO PA-24 Nose Gear Strut Tube
Hi Will -
Here are a few companies that indicate they have access to these two parts.  Ask if they are NOS or As Removed.  Always verify your part numbers and discuss restocking iff needed.
Happy wrenching.
Maine Aviation Aircraft Maintenance
406 Yellowbird Road
Portland, ME, 04102
Phone: +1207-780-1811
Fax: 207-772-6900
macairgroup.com/
Texas Air Salvage
802 Hurt Rd
Bloomburg, TX, 75556
Phone: +1903-280-9110
www.texasairsalvage.com
JT Evans Aircraft Sales, Inc.
2501 S. Orange Blossom Trail
Orlando, FL 32805
aircraftsalesinc.com/
21707-00
Aircraft Parts Store LLC
7403 Philips Hwy
Jacksonville, FL, 32256
Phone: +1904-998-9101
Fax: 904-998-9102
www.aircraftpartsstore.com
Texas Air Salvage
802 Hurt Rd
Global Aircraft Industries Ltd
3445 Hall Road
Kelowna, BC, V1W 2T1
Phone: 780-458-2801
www.globalparts.com
Orlando, FL 32805
Last edit: 01 Jun 2024 11:34 by Kent Dellenbusch.
  • Will Starnes
  • Subscriber
  • Subscriber
01 Jun 2024 10:29 #4321 by Will Starnes
Thanks Steve. Contacted them. They will only repair the “nubs” for the steering hub. They said any crack in the tube makes it unserviceable and they cannot repair it.
I found one at Dallas air salvage.
01 Jun 2024 10:17 #4319 by STEVE ELLS
Hi Will,
It appears as though www.precision-welding.com has FAA approval to do weld repairs on the 21707-000.
I'm not sure they can weld the crack, but it's worth a phone call to find out!
Time to create page: 0.102 seconds
