Home » Topics » Main Forum » PIPER MODELS » PA-23 » From OLD Forum: Replacement Fuel Caps
    Steven Nordstrand on November 13, 2014 at 12:43 am #17517
    Hi I am a proud owner of an Apache. For parts and advice check out the Piper Apache Club on line, join it, it is well worth the money. A guy named John Lumley runs it. There is a Forum that goes back for years. Also Diamond Aire out of Kalispell Montana is a complete rebuild shop. They are also on line. Both have complete cap assembles. Both are a great source of parts and information.
    Good luck.
    lowry watkins,jr. on March 24, 2014 at 5:14 am #17397
    preferred airparts,chapparal parts,wilco,dawson,muncie avn. i have 2 that do not match on apache tiptanks.one is for a cherokee,other for a seneca.
    John Bagnas on June 4, 2013 at 2:39 pm #17197
    From PFA staff:
    Check with the folks at Wentworth Aircraft at 1-800-493-6896 or wentacpart@aol.com. Also, I would try Preferred Air Parts at 800-433-0814 or http://www.preferredairparts.com.
    –PFA
    John Bagnas on June 4, 2013 at 2:38 pm #17196
    From member Bill Wenkman:
    What is the problem with your present fuel caps? If the rubber has become hard and difficult to compress, put the caps in lacquer thinner for about four hours, take them out and check for pliability. If left too long the rubber diameter becomes so large you will not be able to re-insert and then the caps will need to be dried out.
    -Bill Wenkman
    wenkman@verizon.net
    John Bagnas on June 4, 2013 at 2:37 pm #17195
    From PFA member:
    Anyone knows where to get replacement fuel caps?
