Hi Aaron;
I inherited a long towbar that spigots into the cups that hold the nose gear axle in place. I turn a handle to close the two stubs that fit.
It has a tow ring on the other end. It is meant to be grabbed and held by a pintle hook. I have only used it once when due to a malfunction my engine died out of a taxi way and I couldn’t get it started.
I don’t see any reason you couldn’t tow it with a truck but urge you to have a second person who know how to apply the brakes sitting in the airplane when you’re towing it.
You raise a good point when you ask about turn limits. The biggest drawback in using a long tow bar is the very distinct possibility of shearing off the turn limit stops by turning too sharply. This is pretty common when a small airplane (like your Seneca) is left in the care of a big FBO where the line crew is not familiar with the limited turning range of our nose gears.
According to the POH, the nose gear on a Seneca II is limited to a 27 degree arc to each side from straight ahead. That’s not very sharp.
Slow and gentle is always the byword when towing an airplane. I suggest you always have a brake man in the cabin when towing, and be very careful to limit the sharpness of your turns.
If you do those things you should be fine.
Towing an airplane with a vehicle
I have a Seneca III that’s a beast to move out and especially into the hangar. I recently purchased a tow bar that clamps in on the nose gear with a screw mechanism. To tow the airplane I plan to use a riding mower that already has a pintle hook on the front. Then I got to thinking, I could use my truck to tow the plane down to the fuel pump and back. Has anyone ever used a vehicle to tow an airplane? The first gotcha that came to my mind were oversteering the nose gear. Could stopping to quickly overstress the nose gear? Is there anything else I should be aware of? Any advice and “been there, done that” stories would be appreciated.
