Home » Topics » Main Forum » MAINTENANCE » vacuum pump removal
vacuum pump removal
    STEVE on December 16, 2020 at 8:51 am #20401
    Excellent,
    Happy Flying,
    mark miller on December 15, 2020 at 10:17 am #20397
    thanks! My I/A and I came to the same conclusion after reading those docs. the AV-30s are great and it a relief to be able to do the vac pump removal as a minor!
    STEVE on December 13, 2020 at 10:11 am #20384
    Hi Mark,
    I just did the same update. Here’s a lead for you:
    I read FAA Policy Statement PS-ACE-28-08-R1 titled, “Replacement of Vacuum Driven Attitude Indicators in 14 CFR, Part 23/CAR 3 Airplanes,” for guidance on removal of the vacuum driven instruments. I deemed the removal to be a minor alteration.
    I also found the following paragraph in the Notes in the Type Certificate Data Sheet (TCDS) for Mooney singles:
    “NOTE 24: Aircraft models that originally were certified with vacuum powered attitude systems that have those systems
    replaced with a non-vacuum powered attitude system: If the Primary Attitude system has been replaced with an
    FAA Approved STC’d installation that meets the requirements of 14 CFR 23.1303(f)(i)(ii)(iii)(iv)(v)(vi),
    23.1311(a)(1)(2)(5)(6)(b)(c), 23.1321(a)((c)(d)(1), 23.1331(a)(b)(1)(2)(c), thereby leaving no operational systems
    dependent on a Primary or Standby (if equipped) Vacuum system, then the Primary and Standby (if equipped)
    Vacuum pumps and associated lines, manifolds, etc may be removed from the aircraft. Refer to engine
    manufacturer’s instructions of removal and capping off of engine driven vacuum pumps.”
    I have asked Piper to insert the same paragraph in its TCDS. I’m not sure if they have.
    The approval for installing a blank off plate over the vacuum pump pad is the illustration in the Lycoming Direct drive service manual.
    mark miller on December 12, 2020 at 6:38 am #20379
    Just bought two of the certified Uavionix AV-30-C units and installed, replacing my AI and DG. The STC supplied allows the replacement of the vacuum driven instruments with the new electronically powered units. the AV-30s each have a backup battery built in. there is no provision however, for the removal of the vacuum system ie: tubes, filters, vac pump. There is nothing else connected to the vacuum system now that the AI and DG have been replaced. What is the process for legally removing the remainder of the vacuum system?
