Home » Topics » Main Forum » MAINTENANCE » Early Cherokee cabin Air cable
    Kent Dellenbusch on August 1, 2020 at 6:52 am #20077
    Glad you can use your current cable. Keep McFarlane in mind should you ever want a spare at hand. Have a great weekend.
    Dennis Dunaway on August 1, 2020 at 6:44 am #20076
    Thanks, Kent for now I think I can save my old cable but you never know.
    Kent Dellenbusch on July 29, 2020 at 7:52 pm #20069
    Hey Dennis, if a cable is needed McFarlane does make custom cables. https://www.mcfarlaneaviation.com/products/category/cables-and-chains-flight-control/ You will have to reach out to them but they do have the capability of individual requests.
    Dennis Dunaway on July 26, 2020 at 4:23 am #20065
    Steve, Thanks this should work
    STEVE on July 22, 2020 at 12:08 pm #20063
    Hi Dennis,
    Sorry it’s take time to get back to you. I can’t quite see what you have going at the attach point. One thing that comes to mind that might work as a solution is what’s called a wire swivel. It’s commonly used to connect the control wire to the carb heat arm on the airbox. The body of the swivel is put into a hole on the arm, then the control wire is put through the hole before tightening down the screw onto the control wire. 06-01282WireSwivel.jpg Aircraft Spruce sells these things for less than a dollar. The Aircraft Spruce part number is 06-01282. I’ve attached a picture.
    Dennis Dunaway on July 17, 2020 at 5:51 am #20050
    Annotation2020-07-17075026.png 20200717_132332.jpgThe cable end to the cabin Air vent in my 65 Cherokee 180 keeps coming off. I don’t think it is original as to how the end is attached to the door.
    This is the vent that you control from the push-pull knob on the right side of the lower dash and open the vent door on the forward left of the cockpit by the pilot’s feet. This vent also has a knob on it.
    Any assistance/picture as to how this should be installed would be appreciated.
