Home » Topics » Main Forum » AVIONICS » Strobe Power Supply Location on the PA28R-201T
Posted In: AVIONICS
    STEVE on April 5, 2021 at 9:51 am #20594
    The power supply is aft of the rear wall of the baggage compartment. The drawing in the service manual shows which wires for the left and right wing. Plug #2 (shown on power supply) is to the left wing and plug is to the right wing.
    Plug 2 is the upper right plug; 4 is the lower right plug when looking at the power supply from the end where the wires enter.
    You can unplug the strobe wiring at the power supply.
    I hope this is the information your seeking.
    Kent Shaw on April 1, 2021 at 7:45 pm #20589
    The power supply on my Warrior was in the tail section. I am fairly certain that the power supply generates about 400v rather than 48v. You should be able to bypass the power supply and use existing wiring to power the UAvionix.
    Luis B. Arguelles on April 1, 2021 at 11:37 am #20585
    Hello! Hope somebody helps with:”Strobe Power Supply Location on the PA28R-201T”, the plane is transitioning to the “UAvionix” “Nav LIGHT/Strobe/SkyBeacon” and the “UAvionix” “Sky Light”
    Besides Sky Beacon will be damaged with the 48V. from the Strobe Power Supply, that Supply is no longer needed, but I cant find where THE SERVICE MANUAL indicates. Serial N° of the Plane is 28R-7803137. Thanks.
