Home » Topics » Main Forum » AVIONICS » 2015 Avionics project finally done after five mont
Posted In: AVIONICS
    Kent W. Kalb on August 5, 2015 at 5:47 pm #17803
    With you on the $$$$$!!!!!! This is my “end point” as well.
    Anonymous on August 5, 2015 at 5:44 pm #17800
    Hi, sadly no. I’ve spent way too much as it is, lol. I’ll have ads-b in installed on August 21 and then I’m done, done, done! Except for paint, which I’m slowly researching.
    Kent W. Kalb on August 5, 2015 at 5:40 pm #17797
    Are you considering an IFD440?
    Anonymous on August 5, 2015 at 5:39 pm #17796
    Great news! Thanks for sharing,
    Kent W. Kalb on August 5, 2015 at 5:13 pm #17795
    I discovered a “fix” for my lighting issues through NexAir Avionics. It is a setting on the avionics dimmer 28V systems. Connect pin 7 to the aircraft dimmer, and pins 5 and 6 to grouns
    Anonymous on May 19, 2015 at 8:06 pm #17749
    Hi Kent,
    I’m not having any problems with daylight lighting. However, I was curious and there are several lighting options that you can use. Check your manual or with your avionics technician to see which option he used. Then you can figure out how to adjust it.
    Kent W. Kalb on May 19, 2015 at 6:24 pm #17741
    Scott,
    GREAT looking panel. Very similar to my panel. IFD, AMX, AXP…Avidyne complete! Any issues with daytime “lighting” and visibility of the AMX-240 Audio Panel? I can’t differentiate which keys are “lit” daytiime.
    Thanks.
    PFA Staff 4 on May 12, 2015 at 3:11 pm #17733
    Hi everyone,
    After five months of winter airplane projects, my Seneca finally rolled out of the hanger and got gassed up today. Out came my Garmin GNS-530W GPS, GMA-340 Audio Panel and Narco transponder. In went an Avidyne IFD-540 GPS, AXP-340 Mode S ADS-B Out transponder and AMX-240 Audio Panel. My Garmin GMX-200 MFD and GDL-69 datalink weather receiver have stayed. Thanks to Avidyne’s interoperability, it all plays perfectly together. I’m glad the project is done and can’t wait to use it on my first flight tomorrow. I’ve attached a couple of pics.
    Happy Spring to everyone,
